Ranger Cooling
tyler, jason... and other TTB ranger ppl, how does the radiator and lower hose sit in relation to the steering box? this is still the only problem i am having trouble with as far as working out my SAS. thanks in advance.
my lower hose passes right next to it. dunno if this changed at all in '93 or if it's still similar. tyler is definitely the one to talk to here. I can't find his email, but I'll see laura this week at work so I'll get ahold of him somehow and see what he has to say.
??passes next to it as in BESIDE it or IN FRONT OF it? my radiator has the lower hose attaching at the bottom driver side of the radiator sitting almost flush against the inside of the framerail. this is where i need the steering box (i think) so i need to know if the old ttb rangers had a radiator with a lower hose connection 2-3" toward passengerside. thats my suspicion... and if it turns out to be so, then i simply need a radiator from a ttb ranger.
- You may not post replies
- You may not edit your posts
Forum Rules
