Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: Fix this car....
    ill be your pickup man
    San Antonio, Tx
    Fix this car....(90 Bronco)
    Let me type out loud here...
    I am thinking of picking up an unmolested 90 Bronco with a 5.8 and 70k miles. Owner told me that he thinks its has a fuel pump problem and after a quick look, one of the cardoc guys thinks the same thing. I got in it earlier and it started right up (been sitting for 2 months). I drove it maybe 100yards and it died completly. Now it has no acccesory power, but headlghts/interior lights work. No windows, radio, starter, fuel pump.
    The ignition lock cylinder is damaged, but I do not think it is issue. I am thinking the starter switch on the column. When you turn the key, nothing happens.
    I am unsure, only because i looked at it for like 20minutes in the dark.
    What do ya'll think?
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
    San Antonio, Tx
    I worked on it today and got a new switch and lock cylinder installed and repaired a damaged fusible link near the battery area. Also installed new battery and cable ends. I now have all accesory power. I am also getting fuel, but no spark. Checked all the fuses as well as the ICM. It cranks, but will not start......
    ideas?
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
    Quote Originally Posted by JBrown89
    My blazer does the same crap... never figured it out.
    1988 Blazer...RIP
    Registered User
    Jul 2006
    did you check the starter?
    San Antonio, Tx
    Quote Originally Posted by bcolman
    I ruled it out due to not having spark
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
    fbronco86
    How are the battery connections?
    Ground?
    Do you get no spark and no fuel pump at the same time?
    Dec 2005
    BFE, Tejas
    This will fix it...
    ... TMatheaus's Avatar
    Nov 2005
    Bayou Vista
    ignition module or the pick up coil
    Tommy Matheaus '06
    210-323-2546
    2004 F-140 4x4 DD
    1990 F-150 4x4 in the works
    lowballing someone
    Feb 2005
    Houstonish
    do you have a condensor on that thing?
    Sep 2004
    Quote Originally Posted by colman
    condensors are used with points ignition.
    1976 F-100 Kustom Krawler
    1976 F-150 Custom
    1964 CJ5
    fbronco86
    Hello 1990 how about fuel injection
    hall sensor, pick up, coil are the parts for a ford FI
    San Antonio, Tx
    I tested the old ICM and it was good, but I warrantied out a new one just for Sh&Gs.
    Battery connections are new. I jsut put in a new battery and a new positive cable and new new neg cable end today.
    Anyhow, I still have now spark.
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
    fbronco86
    Are you getting 12 volts at the coil when you are cranking?
    San Antonio, Tx
    i do not think I am getting power to the coil
    replaced eec relay today, still no start
    92 YJ
    04 F-150 4x4
    11 F-250 4x4
  15. #15
    fbronco86
    Is the computer getting power?
    Could be the ignition switch.
    The best way to solve this problem is to get a voltmeter and see where your voltage stops. Or you can aimlessly replace parts.
