i got a 12 bolt and a dana 44 front, im lookin for 200 both
what side drop 44 and is it set up for spring over or spring under?
6 or 8 lug?
Clayton Rollins '08
210-863-1435
2007 Dodge Ram 3500 4x4 5.9
1983 Waggy
6 lug spring over passenger side front 42.5" between the perches in the rear dont recall the front right offhand. Should have flat top knuckles but they cannot be used for 8 lug conversion.
dammit i need a drivers side drop, oh well
Are they full-width? I was considering getting some toyota axles for my sammi, but if these'll work it might be better to pick them up.
what gears are in them
The gears are no good in them, you will have to replace them, but its spring over. They are full width. Andrew, its the axles you sold me!
i had a friend looking for a pair. whats wrong with the gears hat are in the front. they were 3.73
they are from a 72 blazer. the rear factory 3.73 nd posi went into another truck
Paul, I've got a meeting with my advisor at 4:15 tomorrow, so I'll probably be by to take a look at them about 5:00ish. Is that cool?
Yeah I forgot the gears in front are r good. Just the rear ones are toast.
Paul I just got your message. Did the guy pick them up today?
