Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: Carb problems...
  1. #16
    i got sick of carbs so i converted to efi and love it
  2. #17
    how did that chip work out?
  3. #18
    it runs very well, not quite perfect but it will work till i get a chance to tune it myself. thanks alot.
  4. #19
    Quote Originally Posted by FJAggie07
    Oh fawk i think i over torqued the damn thing and now i have a vacuum leak...sonuvabeech.
    colman
    Quote Originally Posted by colman
    vacum leak
    Echo in here???
    Oh wait, he graduated from bad punctuation to ****ty spelling...
  5. #20
    my keyboard is sticky (spilled a drink you pervs)
  6. #21
    any pinging?
    did you set it to whatever base advance I wrote down?
    I couldn't find any timing tables for the 258 so I hooked up the drb2 scanner to my brothers 4.0 yj and just used whatever vacuum and advance it displayed.
  7. #22
    yep its at 8 degrees, i did get 17 mpg on the way back from galveston with the 37" tires
  8. #23
    Nov 2002
    Tx
    Alrighty, got the leak fixed with some rtv sealant, had my best friend come in and help me get the mixture right, and now I am going to drive it home tomorrow 2.5 hours
    (let's hope nothing beaks...)
    Make sure you're not using the coil hot wire to power your choke. The choke can suck a lot of juice cause it's basically powered on the whole time, causing you to lose some of your spark.
    Personally, I woulda just stuck with the old mechanical choke carb. I rebuilt the carb in my old 72 FJ40 and it ran great. I like having the mechanical choke, just like most other mechanical vs. automatic devices, cause it puts you in control of the process. It just sucks when you forget to turn it off.
  9. #24
    Quote Originally Posted by mudtoy67
    It sucks gettin old don't it....
  10. #25
    Nov 2002
    Tx
    Quote Originally Posted by DRAGOONRANCH
    Heck, I was 16 at the time. Come to think of it, that's getting to be a long time ago...
  11. #26
  12. #27
    DFW
    Actually I was getting really tired, and I quickly ran the choke into the headlights. I didn't set the choke screw just right before I ran it home and it ran like a scalded ape the whole way home hitting close to 85 mph of certain stretches of 45, and I knew then that I had screwed something up. I got it to my ranch played with the choke screw, idle and mixture and throttle cable and got it idling a LOT lower but now i need to fix my throttle cable cause I cut the housing too short and it is acting like a governor...oh well. Then my dad stuck the damn thing on the front of our property cause the tires are so bald...
    Got to use my winch...so no harm done.
