Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
Thread: Mounting a high lift jack to Roll Cage
    Dirty Old Man! 8Runner's Avatar
    Bryan, TX
    So I need some creative ideas on how where to mount a high lift to my roll cage. Ideally it would be somewhere semi-protected, but not interfere to much with the back seat area, but that may be hopeless on both counts. These things are pretty, but jeez, $89 to mount a $50 jack that's probably gonna get mangled next time I roll hard?
    Ideas?
    Thanks,
    Chris Scotti
    1988 Suzuki Samurai buggy
    Dec 2002
    Austin, TX
    Not lockable if you're worried about that, but these are pretty cool. Sierra Expeditions is a great vendor as well.
    http://www.sierraexpeditions.com/ind...3/prevstart/0/
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    weld two bolts to the cage, use wing nuts to secure the jack, then drill out the end of the bolt so that you can put a small lock on it if you think someone will try to steal it. ten bucks and you are done.
    lo veo TxCruzr's Avatar
    Apr 2003
    Arizonaaaaah
    Like kevin said or what I used on mine were some u-bolt thingies that are used on towers that my dad had extra of. The piece that slides over the u-bolt is made to fit around tube so it fits snugly against the cage and doesnt slip. The holes in the jack fit over the part of the ubolt sticking out and then uses a plate to sammich the jack to it. Use one on each side and one has a lock on it. Very simple and removable. Probably find the clamps at a radio shack maybe or online.
    like this but w/o the thingy on the left
    Oct 2004
    Headed back to the Big D
    exhaust clamps and a wingnut on one of the bolts works well too
    Wylie, Tejas
    Just wheel with your brother and use his.
    Boats and hoes
    Bryan, TX
    Hmm, I like those Quick Fist things, Kevin. Then I could move it if I had too. I am not concerned about lockable. I saw a do it your self using exhause hangers somewhere on the web, but it looked like a pain to get the jack on & off.
    I also need to figure out where on the cage I am going to stick it, any opinions there? Maybe I could use those quick fist deals and attach it to the tire carrier. Might stick out too much or get whacked hard if I roll though.
    Thanks,
    Chris Scotti
    Chubby Bunny davido's Avatar
    Mar 2002
    College Station, TX
    Hmm. What's a jack for?
    Dec 2005
    BFE, Tejas
    to pull dents out of motels
    Mar 2002
    College Station, TX
    Apr 2003
    Arizonaaaaah
    maybe in one of these spots if you have room....on the inside of the tube, not the outside
    the yellow line is the jack standing up right infront of the tire...depending on how much room you have there, the tip of the jack might be sticking out or you might be able to cut the tip off and shorten it
    Dec 2005
    BFE, Tejas
    im liking either the blue or the red lines
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    Blue looks the best to me.
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    dark blue it what i ahd envisioned when i saw the first pic.
  15. #15
    Aug 2002
    is there room straight across behind the seats?
