So here is my problem, If anyone is on TDR post this up there and see what brilliance they come up with.
I have an early year 1999 Powerstroke with the 7.3L 6speed. It is bone stock. I have done regular maintenance (oil, filters, front axle bearings, etc…) The only major work done to it was a clutch job and transmission rebuild. So the other day I was pulling my car hauler with my friends Scrambler on it (5000 to 6000 lbs) and the truck stumbled. By stumbled I mean it was like the engine cut out for a second or 2. It was raining at this time. It did this several times and eventually the “Service Engine Soon” light came on. Upon turning the truck off and on the light would go off. I went by my friends shop and we hooked a scanner up to it, there were no codes in memory. We drove it around and got the light to come up. The scanner would show the light was on, but it still showed no error codes.
To me the stumble felt like a knock sensor on a gas engine or perhaps the cam sensor. I have heard these trucks have issues with the cam sensors, so I went and bought one at O’reilly’s. Installed it and assumed everything was ok. This was last Sunday. Monday I had no problems. Tuesday it was again raining and I felt the stumble several times. One time while sitting at a light the truck died. I restarted it with no problems. At this point I figured I had a connection that water was getting into and causing the problem due to it happening only when it was raining.
Well last night I was driving back from Beaumont and my Battery light started coming on any time the engine was under about 1000 RPM (while stopped at lights) My question is does anyone have any idea about these? Are they related? Or do I just have a possible bad battery/alternator and some other problem causing the stumble? Any help is appreciated.
