Anyone able to fix a cracked tube on a copper radiator? ive already put stop leak in it so thats not an answer
solder it
Tommy Matheaus '06
210-323-2546
2004 F-140 4x4 DD
1990 F-150 4x4 in the works
JB Weld
edit- theres a radiator shop in bryan. i think its on cavitt
ive heard you can drop an eg in there and it will cook and seal up the leaks, i wouldn't do it but would love to have someone else try it
ive done the egg and the pepper bit, the egg worked for about 5 min till it burnt up but the pepper is the best so far
get it fixed right by someone or solder it if you know what you are doing. Kopecki's old 258 radiator was prolly only a one core by the time he had fixed it so many times.
i soldered the radiator on my jeep from where the fan ate it in the wreck, wasn't hard just took a few minutes to do, just have to pressure test it a few times and use some soapyness to check for leaks
Tommy Matheaus '06
210-323-2546
2004 F-140 4x4 DD
