Originally Posted by Eckert
the rears up front is a easy way to do it. You will need to add some leaves from another spring pack of some sort (toy, waggy, xj, etc.). Build a new front crossmember/spring hanger. It'll give you a little more lift and keep the pitman arm and springs from hitting, plus allow you to move the axle forward a little more which you will need later when you get larger tires. And of course you will most likely need shocks. I prefer bilstiens or BBCS, but you can get some 14 inch travel procrap ones for really cheap (30 bucks a piece). Then use a set of ford shock towers (25 bucks) to mount them
As for the rear springs, most people use the 63 inch chevy springs, not the 52". I don't think the 52" springs would really gain you anything. Some people really like the way the 63" inch spring flex and ride, some don't. I didn't like them because of how long they were and how much they stuck out in the rear. But if you are not going to bob your bed, it really doesn't matter as you have alot of rear overhang allready
