saw this a figured a few other people here would think it was pretty neat
http://www.pirate4x4.com/forum/showt...ghlight=dimple
Perfect for Jimmy's SPEEDHOLES!
Flem made some, they almost worked!
Boats and hoes
Originally Posted by BMFScout
we shall see...
we flame hardened them and then quenched them in a special mix of Keystone Light and 30 weight.
Boats and hoes
I have access to heat treating furnaces if he doesn't think the flame hardening worked.
1988 Blazer...RIP
I think flem's design was more the problem than the heat treating, but it seems like we were trying some thicker stuff I can't remember.
Boats and hoes
.125 was the thinnest we did, and that was on the larger one
doug they are 304 SS and after we did the the heat treating I read up on it and I think I saw 304 doesn't respond well to it. Any ideas?
If it was as easy as sticking in the machine and hitting start it's one thing... I'm not even messing with my own **** right now.Originally Posted by agjohn02
1988 Blazer...RIP
any reason you used SS instead of a tool steel?Originally Posted by robertf03
1988 Blazer...RIP
it was freeOriginally Posted by Doug Krebs
same reason my pinion spacer on the rover is inconel 600
if i program the code and drill two little holes will it be easy as sticking it in the machine and hitting start?
yup, but radii have to be accurate to .xxxxx else the machine will crashOriginally Posted by agjohn02
1988 Blazer...RIP
so can i just change the significant digits on my dimensions to five places?
