Results 1 to 8 of 8
Thread: Ebrake cable
    BIGJIMMY
    Ebrake cable
    when i swapped my 10 bolt for a 14 bolt I kept the same ebrake cable on it. One side hooked up and the other one didnt. I tried to get it inspected, but it wouldnt hold while my truck was idleing in drive. So I was thinkin if i got an ebrake off of a single cab short bed 1 ton, would it hook up to my 86 jimmy?
    lowballing someone
    Feb 2005
    Houstonish
    are you taking about the ebrake cable, cause its longer?
    BIGJIMMY
    yea the the ebrake cable, my bad, if its longer, what are the other options that are inspectable, because it has to be a stock ebrake set up for them to pass it.
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    Doesnt have to be stock, just mechanical (i.e. not hydraulic).
    BIGJIMMY
    anybody got ideas on how to rig it up?
    I really don't understand your dillema. Can you not find an e brake cable at the parts store?
    1988 Blazer...RIP
    BIGJIMMY
    will an ebrake cable from a 1/2 ton fit the 14 bolt?
    Aug 2004
    Corpus Christi
    Only one way to find out.
