Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Thread: Chevy 350 Help!
    WURM HULK-1's Avatar
    Sep 2003
    TPC Woodlands
    Chevy 350 Help!
    Hey guys, my DD chevy 3/4 tons motor is running like ****. I went to fill up one day and since then it has been running like ass. It misses real bad, backfires from both the intake and exhaust only at take off. It is extremly sluggish and reaction time is horrible. It also does not want to idle and dies occasionally when driving. The idle also fluctuates from 500 all the way to 1500 rpms. I have changed everything that i could think of that might be causing this problem. I ran all the "bad" gas out of it, changed fuel filter, didnt change the fuel pump cuz it seems to be workin fine and only has 25,000 miles on it. I also changed sparkplugs/wires, O2 sensors, Tp sensor, ignition coil, and new cap and rotor. I am running out of ideas on what could be wrong. My check engine light is fully functional but has not come on. If yall could put in your 2 cents about what u think might be wrong i would greatly appreciate it cuz it has been runnin ****ty like this for a few days now. Fred any ideas? Thanks
    Danny
    Aug 2002
    Is your battery ground tight?
    if it is backfiring it should have a "misfire condition" check engine light.
    Take it to vatozone and have them pull the codes
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    did you adjust the tps when you put it in, to where it reads a certain amount of volts? i know on a ford you are supposed to do this.
    Any exhuast leaks?
    . J Cooper's Avatar
    Sep 2002
    Where you stay?
    Quote Originally Posted by stx4wheeler
    Any exhuast leaks?
    his style doesnt haven an adjustment
    Registered User
    May 2003
    Htown
    there's also, crank and camshaft sensors. Like hippie said, take it to vatozone and let them see what codes it is throwing.
    So you loose, I win!
    Sep 2003
    TPC Woodlands
    i didnt adjust the tps, i dont think on chevys u have to, and i dont believe there are any exhaust leaks.
    Aug 2005
    Houston or a drag strip
    Check the mass air flow sensor? I know the f.p. is practically brand new (I remember helping put it in) but your description kinda sounds like one going out. It'd be a pita but at least it should be under warranty.
    1974 CJ5-The BarnBurner
    Brazos County
    Are you SURE you put the cap on right, it was the right one, wasn't cracked, wires right, etc? what did the old one look like?
    Seth Stewart '04
    2000 Suburban DD
    1998 GMC pickup - sold
    1975 Scout - TBD
    1976 Scout - parts truck
    1972 IH 1310 dually - TBD
    196? Scout 800 - 302 roller
    lowballing someone
    Feb 2005
    Houstonish
    check the firing order/wires ive gotten them off before (2 backwards and it did that)
    Hazaa Fredo's Avatar
    What year is this thing?
    edit*
    Just saw the signature...nevermind.
    I would say either cam position sensor, vaccuum leak and or intake manifold leak at the heads. Also, check to make sure your distributor hold down is tight. Has it been losing coolant lately? Check the oil for water too.
    . J Cooper's Avatar
    Sep 2002
    Where you stay?
    Quote Originally Posted by colman
    you saying they switched themselves around at the gas station?
    Registered User
    May 2003
    Htown
    Quote Originally Posted by HULK-1
    Danny
    not to be gay, but did you check your oil. I had the same truck with the same thing happening. Its been said on this board tons of times, but the intakes leak. i ignored mine. The coolant leaked into the oil, the gear on the distributor got eaten up and wouldnt hold timing, and of course the motor was toast.
    Sep 2006
    DFW
    Quote Originally Posted by J Cooper
    Them things have been known to jump right off them plugs and switch around! Like little snakes them boogers are difficult to keep down. I recommend zip-tieing them to your engine block, apparently the heat keeps them relaxed and on their plugs....
    . J Cooper's Avatar
    Sep 2002
    Where you stay?
    it could be mexicans
  15. #15
    lowballing someone
    Feb 2005
    Houstonish
    he did say that he changed the cap, that could have fixed the original problem but putting wires on in the wrong order would have a similar affect and created a new problem. simple mistake... and don't forget about the little engine gremlins they can do all kinds of wierd things when noone is looking
