Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: Skool me on end mills
  1. #16
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    if you're gonna use a center drill, you shouldnt have to flat spot it. not like a center drill is gonna walk.
  2. #17
    Apr 2004
    Cowtown
    Quote Originally Posted by afroman006 View Post
    Well the "pressed-on-pieces" with the holes in them will be used as guides, but the hole will be partially obscured by the round profile of the rifle barrel running perpendicular to the guide hole. On all the gun boards, everyone suggested using an end mill instead of a drill bit due to the curvature of the barrel. The holes will be all the way through.
    do you have a pic? im not comprehending.
  3. #18
    just take it up to dougs, it no matter, it's not a gun, it's pcs of a gun. the school won't care.
  4. #19
    <------putting tinfoil hat on
  5. #20
    The place off campus also has a mill.
  6. #21
    I figured its not worth the risk on campus these days. The barrel with all the AK parts on it looks enough like an AK to be a potential problem. Doug, if you dont mind doing it at the off campus shop, that will probably work. Using a real mill would also allow me/us to just use a round end mill and mill out the slots side-to-side using the x-y axis on the mill table before pressing the blocks on. Man I'm gonna have to do some nasty **** to Doug by the time this thing is finally done...
  7. #22
    Well after discovering that a single end mill would cost as much as 2 of each of the 4 sized drill bit I would need (8 total, all cobalt), I decided to forgo the endmill idea and stick with drilling em out. If that doesnt work, I will call Dougie.
