Results 1 to 4 of 4
Thread: Why is my fuel pump only getting 6V?
Hybrid View
    TAMOR Obsession Chadnutz's Avatar
    San Antonio
    The fuel pump finally quit about a month ago. I installed a new fuel pump, but I wanted to hear it run before I put everything back together.
    I turned on the key and it wouldn't run.
    I gave 12V to the old pump - no dice.
    12V to the new pump - runs.
    Hooked it back up - no dice.
    Checked voltage into the fuel pump relay - 12V. Haven't checked coming out of the relay, but I figured it would either work or not.
    Checked voltage at the pump - 6V.
    Put 12V on the pump while it was installed but the supply line disconnected - shot gas on my shoe.
    Plugged in fuel line, gave 12V - started right up.
    Why 6V? Any idea what is dead and why it would fail at the same time a pump failed?
    It probably put a strain on the relay and may have burnt a connection in it. Check it out first.
    dirty connections add alot of drain
    May 2003
    Htown
    write your representative and ask him.
    So you loose, I win!
