Page 20 of 21 FirstFirst ... 10 16 17 18 19 20 21 LastLast
Results 286 to 300 of 306
Thread: The General
  1. #286
    Jul 2006
    i cant, i will have to take the ubolt off to remove the diff cover, there is no way around this issue
  2. #287
    Judging by the ground down lower bolt heads I would guess that this is not a major worry of yours!
    i dont speak australian.
    seacrest, you are my hero!
  3. #288
    Chubby Bunny davido's Avatar
    Mar 2002
    College Station, TX
    Why would one remove a diff cover? Oh yeah, to weld the diff. Ah, once and you're done.
    So what u-bolt did you use Brian? Does it come stock on something?
  4. #289
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    here is what it ended up looking like, i didnt make it back out to my ranch today but should be getting some pics brought back to me tomorrow.
    frick-the ubolt measured 5/8"x5"x~13"(i did cut off about 2 inches of the thread on each side once i installed it so you could go shorter), there isnt a part number for the ubolt as they make them custom for you while you wait, i waited for maybe 5 minutes for it to be made,
    Quote Originally Posted by davido View Post
  5. #290
    Mar 2002
    College Station, TX
    Where did you get it made?
  6. #291
    Brian did you notch the webbing or drill it near the tube and run it through? Also, how long was it? Or do you have a part number for it so I can get the guys at Heitman to find it much easier.
    Dave must have skipped SAT sections 1.1-1.3: Critical Reading
  7. #292
    he had it made at heitman in houston who sells semi parts. they are off i 10 somewhere and they made it why we waited.
  8. #293
    Jul 2006
    what every one else said, ill change the fluid when i redo the spring plate and wont do that again for a while
    i had it made at heitman in houston, its the place that frick suggested on the east side of down town, but just go to the nearest truck stop with a repair shop and they will make custom ubolts 24 hours a day
  9. #294
    that is really the best place to get all u-bolts made, they are a higher grade than the stock replacement ones. When I needed new u-bolts in CO the local 4wd shop didn't have them so that's what I did, it ended up to cost half as much too.
  10. #295
    Jul 2006
    rebuilt my front driveshaft, now i just need the flanges back from the machine shop
  11. #296
    Jul 2006
    so i started tearing the blazer apart today......
  12. #297
    H-TOWN
    wow!
  13. #298
    H-TOWN
    wash it all first - you will be much happier working with semi-clean parts. At least hose it down. I would spray the engine with degreaser and hose off.
  14. #299
    Brazos County
    Quote Originally Posted by bcolman View Post
    looks the same to me?
  15. #300
    did i have 4 8 lug rollers behind the garage.....?
