If I were to do coil springs/radius arms in the front I would need?
A 60 that came with rad arm coil spring setup? Did any 60s come with radius arms?
Extended radius arms to get rid of those ****ing drop brackets
thats it?
I think you can use these.
http://broncograveyard.com/bronco/i-...rm-mounts.html
You can use the 78-79 setup like Ed posted above with weld on things, most people make extended radius arms and therefore new radius arm brackets. This is what Frick did. Search the Big Nasty build thread.
You can also make some link points out of plate, similar to an anti-wrap bar bracket, but on both sides and then make your own radius arms. and use heims or bushings to connect the arm to the axle.
Check out fullsizebronco, seems like they would have lots of crap like this.
Where are you going to do all this and who's going to fix whatever you inevitably **** up?
Garcia's in Dilley has the best large mexican plate in Texas!!!!
There goes tommys book money
thanks jb. If you see any more let me know. I don't have the funds at the moment
