Page 47 of 132 FirstFirst ... 37 43 44 45 46 47 48 49 50 51 57 97 ... LastLast
Results 691 to 705 of 1980
Thread: Sloth
  1. #691
    So I have decided on a parallel 4 link up front and a 4 link in the rear. I figure once I have it the entire suspension torn out i'll make it awesome.
    http://www.pirate4x4.com/forum/showthread.php?t=204893
    so the shopping list includes
    1 stick 2" 3/4 wall dom
    2 foa coilovers
    4 heims
    1/4" plate
    rear:
    8 heims
    coils
    shocks
    1/4" plate
  2. #692
    DFW
    Quote Originally Posted by JB View Post
    Alot of 3/4ton and 1 ton trucks do not have the plush life of back and forth to work on the highway and pulling a trailer 5 times a year like yours does. Alot of them are used in more adverse everday working type conditions and in this aspect, one could argue that a solid front axle is more 'heavy 'duty, than an IFS setup.
    you just described 95% of this club that owns 3/4 ton trucks. And my comment was directed towards this club.
  3. #693
    radius arms flex just fine. I'd keep the rear leaf spring and since the front already has a ghetto dropdown bracket I'd do homebrew radius arms with a homebrew frame mount and the stock 60 axle mount.
    I don't think lack of flex is the vehicles limiting factor. Radius/leaf will lower the scrap yard odds too.
  4. #694
    How much longer do you have at A&M? How long are you going to be staying at your current place (ie. how long can the bronco be torn down and re-assembled correctly)? The reason I ask is that projects almost always take an a$$ load longer then expected and there is nothing worse then having to move or rush a project before it's correctly finished. Seems like a cool end product if you go ahead with the 4 links BUT how long is it reasonably doing to take you. I say add 3-4 months to whatever timeline you formulate just because of lack of motivation (for anyone in the middle of any project) and hold ups with potential problems and material shortages. Also, what trails have you wanted to do that you would think would only be possible with the proposed suspension? Clarke's old bronco, JB's bronc, Dave's FJ, Brian's K-20 have all bashed there way up every trail I have seen them point their rigs at and all with leafs (if i'm not mistaken). Just my two cents. Think long and hard before dumping time and money into an aborted project.
    i dont speak australian.
    seacrest, you are my hero!
  5. #695
    2 foa coilovers
    4 heims
    1/4" plate
    rear:
    8 heims
    coils
    shocks
    1/4" plate
    are you going to have someone drill and tap the links for the Heims. If i were you i would go with 1.5 sch 40 sleeved w/ 2inch sch80
  6. #696
    with your mom
    Go radius arms and chevy 56's in the rear and you will have more then enough flex and for a fraction of the cost. Also radius arms act as a sway bar thus helping streetability since you know damn will thats where this thing will spend most of its time.
    The parallel 4-link has crappy ground clearance and cost a **** load, also no need for coilovers, get a set of deaver coils and bilstien shocks and you will be amazed. As for the rear 4-link, I think and you know as well you are getting way in over your head, just do a 2.5in chevy leaf spring swap that you can build your own pack and it will flex more then you can imagine, just add a traction bar. But most of all, remember its not all about flex and what you read on the web, stay inside your means and most of all your fabrication abilities and save yourself a huge headache and risk trashing your baby, ask me how I know..
  7. #697
    I'm going to make radius arms from 2x4 rectangular tube. The reason I am doing this is because 2" 3/4 wall dom is almost $10/foot. If I double up the tubes like the aftermarket arms do, it would be over $60 per arm before heims. The Dom arms may look better but bending the tube would be really hard and I would probably **** up at least $60 worth of tube before finishing them. Building the Rectangular tube arms would be simple compared to the tube. I think the Rectangular tube will take more abuse than the dom arms too.
    As far as springs go, i'm going to order the 4" superflex coils from jbg and use one of my existing shocks per side until i can afford some 5100's.
    For the rear, I'm going to do a shackle flip and take a couple leafs out of my superlift pack and use my existing shocks.
    I found a rear axle for it. Funny story actually, I called the guy and he said he sold the front to another guy a couple weeks ago. Turns out he sold my front axle to the guy who I bought it from for $50 more than I bought it for. He wants $200 for the rear. At first I though it was too high, but after calling around, $200 was half the price of everyone else.
  8. #698
    How much do you think the rectangular tube is going to cost?
  9. #699
    Jan 2010
    Quite a bit but there's no bending heavy wall DOM involved.
  10. #700
    Yeah, just cutting stuff at exact angles and then welding it back together at the angle you want....
  11. #701
    Jan 2010
    I know, but that's tumtums problem. I would assume that making a template to use with the plasma wouldn't be terribly difficult.
  12. #702
    sam_hodnett's Avatar
    Feb 2010
    ETMF Land
    We do have access to the stuff to do this with, none of us have access to any bender capable of doing 3/4 wall DOM
  13. #703
    think about it, 200 for a disc brake axle that isn't 30 yrs old.... not bad
  14. #704
    it's $10 per foot too, but I'm only using 3 feet per side compared to 6 for the dom.
  15. #705
    tummy, do something out of plate/sheet metal like you did your winch fairlead mount.
    chopped up rectangle tube is pretty ghetto IMO. Something like this would be nice.
