Nix used a curved one in the back of his truck...not necessarily for lift but to help the ride, and that it did...instead of BOTH tires coming off the ground at the same time when he hits a bump, now only does.Originally posted by Seth
The only real input i have here is on the add a leaves. I have the type that arch, not the flat ones, and i hate them. The ride sucks worse than stock unless I have a REALLY heavy load in the bed. I just can't imagine having then in the front and riding rougher than it is already. If you are going with the flat ones then ignore all this.
SethI would have to consider the NigRedFord a special case though
971
