will a stock 3.73 ring and pinion from a dana 30 tj work in a cj dana 30. the seller says it a low pinion-std cut.
I would not buy untill I have disproved this. I heard that a cj uses a longer pinion than a tj.
I don't think so, Randy's ring and pinion shows a different part number for the TJ dana 30 as compared to other dana 30's
i also think they rotate the opposite ways
nope
YJ's were reverse rotation. The TJ uses a shorter pinion than the CJ, and the late TJ's are metric ring gear bolts....so no, it will not work in a CJ.
this should actually be reverse spiral, it rotates the same direction,just the heal and tow sides have just been swappedOriginally Posted by Fredo
thank you ryan.............. ****sucker
