nm the dimensions, i just read the first post, but is the measuremnt to the inside or outside?
i think the measurment is to the inside, they are the stock spring width i just needed new ones that were square because the stock cj u-bolts are round. So my answer is however the stock bolts are measured is what i need, i would think inside width
can anyone get them for less than 35 bucks because i can get them for that, was just wondering if anyone new of a better deal before i bought
Thats usually the going rate.
bringing this one back to the top. I need to get some u-bolts for my front D60 and rear D70. Where are you guys with bigger axles getting your U-bolts? I've found a few sources for them online, but they all seem to want 70 bucks or more for a set. I'm gonna check at the part stores later this week to see what they have.
12.50 ea is as cheap as it gets for big ones i.e.- 5/8" got mine at BTF. yes, robbie, BTF.
yeah, I am considering the BTF ones, but they want 10 dollars more for the dodge ones, which I can't figure out, since its just 3 ubolts and some studs like the chevy stuff. Plus they don't carry what I need for the rear axle
Carquest is cheapest. I had a 5/8" ubolt from them back when my 60 used them. I think it was under $10. It was cheaper than 9/16" ones from orielleys.
Gooseneck trailer off of 21
goosneck is where i got the ones for the blazer, 13 bucks for 3 with nuts but that was for a d44, they do have larger ones
gooseneck said they didn't have anything that would work, at least on the D70. They were way to short for what I need. I still need to figure out what I will need on the D60, and go back and check on those
if you find them locally for under $45 each,[cartman] i will suck your balls. yes, kyle, i will suck your balls dry.[/cartman]
Go to CarQuest with the dimensions. They can order them or they will know a place to get them made, and they won't be $45 each.
Then go to John's house and try to enjoy having your balls sucked by another man.
Originally Posted by agjohn02
Originally Posted by CRaSHnBuRN
how long do you need them
Yes, yes, and make sure you run to his house so they are good and sweaty. Hell, dont shower for a few days so he suffers as much as possible.Originally Posted by bburris
