Somehow I thought the tubing we had up at our shop had a smaller ID... Well no bueno, it's ID is too big.
Who ordered the tierod material so you can use a tap?
I do but it is going to cost you $.60 and inch
and you can tap my stuff at the same time
you mean as a trade for it? Or tap it in addition to buying it?Originally Posted by AggieTJ2007
in additionOriginally Posted by Doug Krebs
I fixxed the post you are to fast
Oh and I can send it to you along w/ my steering this weekend
You realize it sucks to tap it right? It takes a decent amount of time, plus my taps...Originally Posted by AggieTJ2007
Do you need both tierod and drag link?
P.S. What material do you have anyways?
how bad is taping it, I am sure we can work something out.
The material that I have is an A513/5 1020 DOM 1.50x.375
Well it's fine thread...
So basically I chuck it up in the lathe and face it off. That takes all of 60 seconds. Then depending on how deep you want it, I sit there with a crescent wrench and tap it by hand using the tailstock to hold the tap concentric.
It just takes a while, probably 15-20 minutes a hole, depending on depth. Ask Brian Ritchey or Robert Sharpe, I'm not sure I've let anyone else do it. I think I let Garrett have fun also.
let me see, Ill give you the tube for $15 if you tap mine as well
And all this just costs you time since the school owns all this equipment. JEWOriginally Posted by Doug Krebs
If you've got a manual lathe that starts at full speed tap under power. we do it all the time at work and it's never broken or dulled a tap. lowest speed and just bump it on and off, back it out when it spins in the chuck. Use a ton of tap magic or similar lube on the tap and run coolant on the outside of the material.
Originally Posted by robertf03
i know it works but it sounds so dangerous for expensive taps. i definately wouldnt let someone do that with my borrowed tap.
I'll bet I'm using more expensive taps than you are
Just single tool the fawker with a boring bar.
Hi, I pay for taps! Thats why I let people come in and do it if they want and I don't charge them to use the machine.Originally Posted by fbronco86
P.S. Hello Pot!
