major to minor...
Two trannys (supposedly well built E4OD's with HUGE coolers)
Alternator
Water Pump
Belt tensioner and whatever the little do nothing pulley is...
VAccuum pump twice
Power steering pump
Cam Positioning Sensor twice ( Mechanic screwed the first one up)
Fuel Pump
Rear ring and pinion (gear setters fault... no complaint from Ford)
Carrier bearing
T-case
A set of bushings on my TTB...
Brake rotors that need replacing EVERY time I go tohave them turned.
Various electrical issues
Steering column crapped out on me. Completely **** out it's internals...
Glow plugs
2 Glow plug relays
While Michael may say i didn't take care of it I prefer to say it was used. I used it for ranch work... pulled a lot of heavy trailers... made a lot of trips... but I have changed the oil every 3500-4000 miles, changed the fuel filter every third oil change, changed my tranny fluid and filter every 5th oil change, and kept reasonable records of all of it. I have also let it idle cool and warm up before using it hard. I have not avoided long idle periods... I don't belive I will ever own a diesel truck i can't let idle for long periods... that's a manufacturer's issue.
Frankly... I have been relatively pleased with my PS, but not enough to buy another. If I thought I had had a lemon I wouldn't feel as bad, but i see the same thingsd happening to other PS owners and shake my head.
Another note... my truck only has 175,000 miles... and folks say Dodges are built poorly? I personally been pretty impressed with how well those I've seen get old have held together... even work trucks.
Doug
Since my father was the original owner, we have all service records since June 6, 1985 to the present; that's every oil/filter change, glowplug service, fuel filter swap, and yes, all 6 Raptors.
