dyskrasia
did you check on the red 4runner? The one the thread was all about?
D-FENS
i saw a 4runner at ahmed's place out on 21
Registered
never got around to the red one. they did sell it for $1200 this past weekend though.
i think im going to cruise down 21 and look at the '86 tomorrow. and whats this ahmed? if i find a 4runner im not wasting much on a swap. thanks for the info though. there just no reason to when i got a 283, powerglide, and NP205 sitting at the house. looking to find something somewhat complete so I can slowly build it and not have to go balls deep right away.
dyskrasia
was that the newer 4 door version? If so, last time I was there it was marked as being sold. Also the FJ-80 axle's were gone as well
D-FENS
not it looked like a blue(i think) old body style, not the newer red one that was there a while back.
dyskrasia
I may need to make a trip back out there as well and see what he would take for a set of rear springs from one of those trucks.
Registered
where are these places at?
dyskrasia
next to Mack bolt and steel on HW 21
Registered
went and took a look at the blue 86. it doesnt have much of interior unless you count the aluminum cans. body is in decent condition. i dont think its worth 1100 though.
04-12-2007, 11:17 AM
#100
Regsitered Uesr
04-12-2007, 11:33 AM
#101
Originally Posted by
JeepPhisherman
but it is 2wd
04-12-2007, 12:44 PM
#102
Regsitered Uesr
04-12-2007, 01:00 PM
#103
dyskrasia
2wd drives can be converted pretty easily. All you need is a front axle (which you need if its IFS anyway) and a t-case and tranny from a 4wd, which can be had for a couple of hundred bucks or less. They frames are actually better for performing a SAS because there is less to cut off and the front of the frame allows you to run a lower lift. Plus they are normally alot less abused and in better shape. If you can get one for a good deal, don't ignore it simply because its 2wd
04-12-2007, 04:18 PM
#104
Yeah that project Quasimodo on Pirate started out as a 2wd truck... that sucker sure is purdy.
- You may not post replies
- You may not edit your posts
Forum Rules
