never mind i fixed it, one of the bolts holding the compressor to the firewall penetrated too far into the internals of the compressor and was actually becomming electrified, so i put a nut on the bolt to act as a spacer and everything is all right and finished. FINALLY. the only thing that is left is to adjust tire pressure, and get an alignment.
And don't listen to a thing Eric says, he will have you putting in a pick and pull special.
