Lookin good![]()
i say you sold the tires and rims on tx4x4 what ones did you get to put on there now?
Looking good. Those hummer rims def suck the track width in some. Also, the rear looks pretty far forward, is that from shackle flip?
Drive it yet?
1. Drill out stock pitman arm to 3/4" and install, and attatch steering done
2. grind off stock coil buckets
3. install 78/9 coil bucks and drop 3" for more lift (maybe) for body lift removal
4. install f-250 shock mounts
5. order cheap shocks
6. install radius arm bushings done
7. install sky mfg flip to correct angle and to give enough lift to take off body lift
8. shorten driveshaft and install
9. install trans crossmember done
10. find chevy stub shafts, get ujoints, install with ford long shafts and install with warn premium hubs i have in the garage done
11. front driveshaft install done
12. set new gears (4.88's or 5.13's) in sterling 10.25 with master install kit
13. extend and box arms
14. new softer coils
everything in bold is what i got done. yesterday i also installed a new sag steering pump from an e150 along with the van pressure hose that goes to the steering box.
i also installed an f350 brake booster and MC and bled the brakes like crazy and tey are still really really soft. so i dont know what to do there
seth- yeah i still need to move the rear axle back 1.5" or so. i'll do that before i get my new driveshaft cut. i drove it around the block, but front wheel drive, and no shocks makes for a terrible ride.
colman- i got a set of 37 12.5 bfg mud terrains on H2 wheels for a damn good deal, so i sold the military tires.
damn, should hve showed up for the ride. you keeping the trac bar mount?
i think i changed my mind a little for now. think i'll just get a cheap set of shocks and leave the TTB buckets. when i extend the arms and get new coils thats when i'll change the buckets out to the 78/9 style. i also think i need to lift the rear a little more. it sits a little lower than the front. dont know by how much yet, havent measured. gonna order the shocks this week and shorten a drive shaft i have on thursday. more updates to come
Did you bench bleed the MC before you put it on?
moved the rear axle back 3" today. it was about .5" or an inch to far but oh well. i like it. also installed my light bar
before
after
if anyone is bored im workin on the truck. installing new arms and coils and buckets and shock mounts and shocks. call me at 2103865708 if you wanna come by
workin on it again for anyone who wants to come lend a hand or just watch or drink some beer
pics soon but i got my new extended radius arms in, new coils, buckets, shock mounts shocks, front axle, steering, trac bar and track bar mount in its way to tall. the body lift needs to come off soon
