or notch the insert. assuming you use a 3/4 heim with .188 wall there is plenty of meat
www.qscomponents.com
This is where I got my track bar "panhard bar" ends from. I think I went through ebay.
Sharpe you probably already figured it out but I think the panhard guidelines are that it should have the same geometry as your drag link (length and parallel) and they should both be as flat as possible (parallel with the ground). I'd put a poly bushing on the bottom end and a joint (heim/johnny joint/whatever) at the other
I was just going to use fairly inexpensive heims at both ends. Is 5/8" big enough or should I go 3/4?
Thanks for the link Matt, here's the ends from there
http://www.qscomponents.com/58mr.html
$7 each, nice.
Their bungs arent the right ID for the tube I want to use though (already have it).
i agree with the hippie
Bushing on frame or axle end?
this is pigpen, is noise a huge concern?
Who said anything about noise?
