1983 Ford Bronco
Transmission: NP435
T-Case: ?? Chain or Gear?
Rear Axle: 8.8 or 9"
1973 Mustang:
Rear Axle: 9" 61.5" WMS??
Toyotas: WMS-WMS width?
1983 Ford Bronco
Transmission: NP435
1973 Mustang:
1983 Bronco should have a Ford 9" rear
-no idea on the t-case
71-73 Mustang 61.25 inches WMS - WMS
Toyota rear: who cares?
hey cheif....i think 81 or 82 was the last year of the 9"
Steven W
02 Dodge 2500
are you considering putting a ford rear under the mazda?
I checked the Powertrax website and it had both listed from 1983 to 1986.
http://www.powertrax.com/fordtrucklr.pdf
Ford 9 was used until 86, 8.8 was from 83 to 86 - in fullsize Broncos
you get whatever they had sitting in the pile that day.
my 85 has a 8.8.
I know someone who wants less than $500 for an 83 Bronco with an NP435. The body has some bad rust on the lower parts of it.
He also has a Mustang with a 9", but he wants $400 for the axle alone....
after 1980 the 9" was only used in 4wds
flashlights kicked ass...somehow it didn't cross my mind to put on a glove when driving with my hand hanging out the window?
YJ may be a good option. Hell, the cherokee may even be a good option. Yota ones just use the a crappy attachment system with a spring and these two crappy screws that go through a couple tabs that bend. I just need something I can weld into the existing sockets that will result in a solid adjustment and attachment system.
would cheapy off road lights or traqctor type lights not be a good option?
