Thats what I thought. SO the only thing I might have to change would be the neutral safety switch?
or bypass it
Tommy Matheaus '06
210-323-2546
2004 F-140 4x4 DD
1990 F-150 4x4 in the works
damnit, this guy is telling me that the extension housing is different from an AOD. Maybe I find someone in CS that knows more
Isn't your bronco an pre 87? They came with c-6's and BW1356s If you ran into problems just find a crossmember in a junk yard. Just do it I seriously dout you will run into many problems.
Hell you could drop the trans, pick up mine and test fit (suposed to work fine) then decide if you want to rebuild a c6 or aod.
86 302s were EFI, it was the first year, They came with AOD.
I want it done sooner rather than later adn work is kicking my ass. I am only home on weekends. AOD can be rebuilt for 650 at Deans. Still thinking about it.
FSB says that I might have to do some junkyard hunting for a few other things to make the c6 work.
I'm chadnutzing this thread up aren't I?
yeah fsb has some good info, but it also has some d-bags that regurgitate something they heard from some other guy. They said i couldnt run crossover steering on 6 inches of lift and get the angles right. they were wrong.
Steven W
02 Dodge 2500
