Even at 225K I have never seen a worn out clutch disk on those trucks. Not to say they couldn't have taken off in 2 every time and wear it out. If you replace it make sure to replace the throw out bearing and the $15 sleeve it rides on. That's more likely your problem anyway. While you're replacing clutch parts replace the little plastic bushing where the clutch pedal hooks to the master cylinder.
