ahh shiattt
I need help asap!
I have a Female side of a torx bit that is completely stripped out...
How do I get a female side out?
Im at my apartment with the jeep half apart except for one side...
ahh shiattt
I need help asap!
SHUT UP AND WHEEL
Steven W
02 Dodge 2500
Well, if you drill the head off of the torx, you can remove the part, then more than likely without tension on it, what is left of the bolt will spin out by hand once the part it is holding on is out of the way. If not, at that point vice grip it out.
My dremel, vice grips, and drill are all at home...
Looks like I will try the hammer and allen. If that fails I will try and pick up some vice grips
Thanks guys,
hope this works
SHUT UP AND WHEEL
Its a T-55, and I don't have any allens that size...
*waits for GF to come home so he can bum a ride to sears for Vice grips*
SHUT UP AND WHEEL
5 gallons of gas + match. Preheat it, then it'll come right out.![]()
or you could come by here and borrow what you need
theres not a bigger bit than t-55 you could hammer in there?
so its for the sway bar. so it has a nut on the back side. is the head of the bolt just spinning?
channel locks?
Are you that concerned about a sway bar?
A TJ on the street?! I sure as fawk would be!
