Don't be jealous Scott.
someday I'll take the plunge
these guys run Toyota drivetrains and 42" TSL's... If they can do it...
http://www.offroadsolutions.com/medi...awl04_2008.pdf
for st. john, fred, and whoever else was talking about thread engagement when we thought a intake bolt stripped the head. i'm just going to put the longer bolt back in and forget what i saw.
I got a tbi setup from a 92 craprice for cheap. after i get the intake to stop leaking, i'll start stripping the harness.
tight, you maybe wanna look at getting the 454 tb
is this a 360 or 390?
and did that caprice have a 305 or 350?
I think the computer part # will end in 846. if so you have to run a manifold temp sensor. You could switch to a truck computer and use the same harness but no temp sensor if you want it to be more simple. thats what all the aftermarket crap does.
360
you gonna get a new head?
Deffinately try to get a 454 throttle body, they are MUCH better (bigger bores and higher volume injectors) than the small block ones. The 305 and 350 TB's are the same, I think even the injectors are identical.
Sharpe, it's a 1 7/8" bore versus a 2" bore on the throttle bodies. The small block ones will flow enough for a factory headed FE 360. The injectors for a 305 and 350 are not the same. But, we snagged a set for you at the junkyard today Cook, so you'll be good to go there. We gave them to Flem, so he'll get them to you when he returns to CS.
also discovered today that i had two dead spark plugs, 1 and 8. i know number 1 was dead/dying before clayton because i had no flash from my timing light. thought it was broke
after a fire that pretty much destroyed the air cleaner/hoses/spark plug wires/wiring under the hood, fuel injection by flemco.
Looks good, I wish there was Flemco Sales office in Houston...
Looks like there will be after today's fair.
Flemco/Fredco fuel injection is by application only, and by that I mean you can't be a fag.
