Page 47 of 82 FirstFirst ... 37 43 44 45 46 47 48 49 50 51 57 ... LastLast
Results 691 to 705 of 1217
Thread: Swamp Donkey Progess
  1. #691
    [ED]
    Quote Originally Posted by JBrown89 View Post
    your strap-on is in the back of the Bronco again. I took it with me this past weekend. Go get it.
    Fixed it
    [/ED]
  2. #692
    If I didn't have this ****ty internet you wouldn't have beat me to it...
  3. #693
    The Lightning put 350 to the wheels and something over 400 on the torque. That was with only 3lb of boost. The goal is 8lbs, but they found out it needs a bigger fuel pump. After we get a bigger in-tank pump in it, it will get retuned.
  4. #694
    I finally pulled everything apart this afternoon. The cylinder walls have scratches, but nothing you can feel with a finger. It looks like if you took some steel wool and roughed up everything. There is also light rust from being open without spark plugs for 3 months. Other than that, nothing blatant stood out. I need to borrow a hoist to get the motor out so I can pull the pan to see what lies inside. Brandon? Do you still have one?
  5. #695
    hmm, interesting, at least you know the heads are good
  6. #696
    Clarke owns one at Dexter, you'll have to see if he will let you borrow it.
    i dont speak australian.
    seacrest, you are my hero!
  7. #697
    with your mom
    come get that *****
  8. #698
    i have one also that i regularly whore out, let me know if you need it
  9. #699
    Registered Eckert's Avatar
    Nov 2006
    [QUOTE=colman;221641]i have one also that i regularly whore out, let me know if you need it[/QUOTE
    used and abused. its a testament to HF.
  10. #700
    so not as dismal as we thought. let me know when you pull it and i'll help. did you hear about the lightining?
  11. #701
    Quote Originally Posted by sasquatch View Post
    I dunno, the motor still doesnt turn by hand. Somethings definetely ****ed inside.
    The Lightning is also fooked and back over here. Water in the oil. He got the front oil leak fixed. It is going in the garage sometime this weekend once I get everything BACK out.
    Pull Bronco motor maybe Sunday, maybe next Sunday.
  12. #702
    We just unloaded the Lightning and got it in the driveway. He thinks the leak is coming from the intake gaskets that we reused. He ordered some new ones and that would be great if that fixed the problem. It still has two small oil leaks from both heads near the back somewhere.
    Once these issues are fixed, the next step will be more fuel, 8lbs, and a retune.
  13. #703
    come get that *****
    I might come get it Sunday. Motor has to come out with trans AND somehow make it over the new bumper/stinger. Will be interesting.
  14. #704
    you can't drop the trans and then pull the motor,
    Cut the stinger off and weld it back on later
  15. #705
    why does the trans even need to come out?
