Page 49 of 82 FirstFirst ... 39 45 46 47 48 49 50 51 52 53 59 ... LastLast
Results 721 to 735 of 1217
Thread: Swamp Donkey Progess
  1. #721
    The block looks fine. When I get a chance I am going to drop it off at Harrison's and have him go through it and the heads.
  2. #722
    it was keeping it from turning over?
    put a new rod in and run it like that
  3. #723
    Registered william_ace's Avatar
    Feb 2004
    College Station, TX
    thats what i would do, why do you think the heads need to be checked?
  4. #724
    what ever bent that rod surely had to spread that force somewhere.
    What put the dent on the skirt?
  5. #725
    the crank counter weight made the dent thats why it wouldn't turn
  6. #726
    VW Ninja Jackasic's Avatar
    Jackasicstan
    that sucks john
  7. #727
    I dropped the block of at Harrisons shop today. Should be checked out, cleaned up, and reassembled in a week or two. Anyone ever seen his shop?
  8. #728
    Quote Originally Posted by JBrown89 View Post
    I think sharpe has had experience with them
  9. #729
    The motor is back together and ready to go in. Is TCC 09 a possibility....
  10. #730
    Yes, and unless there are torrential rains before/while you are there, you won't have to worry about going swimming.
  11. #731
    I noticed this today. It looks like at some point in my limited Clayton experience, I bent a rock rings pretty good. The end of the studs is usually about 1/2" from the edge of the ring. It is flush on 1-2 studs on this wheel. It has a slow leak, but I pretty sure it is not related. I would have fooked the studs good without the rings.
    Tie rod is fooked a little too.
    Motor should go back in Sunday. Memorial Day K-Rocks is a possibility
  12. #732
    Those are Copperhead rings right?
  13. #733
    Yes
    Motor going in today. Colman, this engine hoist could really use some casters, just letting you know.
  14. #734
    Yes
    Zing!!!
    Good, get that biatch running and start helping us hunt a GN for the CO. trip!!
  15. #735
    Any suggestions on good 52" 3" wide springs? Need some for the front.
