I have to reuse them so I prefer not to do it that way... they are for the sport cage I got from creighton... The back bracket is different on mine than his so I have to swap ends
And Harbor Freight.
'81 CJ7 Laredo, 258/T176/D300
i used vice grips or you can knock the pin out with a punch
Why not replace them with a regular bolt and washer that you can put a wrench on? Is there a space issue?
those aren't really tamper proof. you can get them anywhere. tamper proof is the crap that only goes in and can't come out.
I picked one up at sears as well as a file to open up the drain holes to install the cage... sanded and repainted it... looks better
got it in... looks good
Still need to notch these plastics and install them... also need to tie the cage into the frame
or soaked with oil for 20 years
I need a coil spring compressor... I have seen them at places like sears but was wondering the best type to use... or do auto parts stores have loaner ones?
Why on earth do you need coil spring compressors working on a TJ?
