Page 5 of 45 FirstFirst 1 2 3 4 5 6 7 8 9 15 ... LastLast
Results 61 to 75 of 671
Thread: Diesel Truck Shiat - Per Cook's Request...
  1. #61
    May 2003
    Htown
    Quote Originally Posted by StevenAg03
    if you are looking for lubricity i would not recomend using any of the diesel additives alone. they are mostly alcohols and actually brake down the lubricity of the fluids. i add 1qt of non-synthetic multipurpose 2 cycle oil with every fillup. the truck seems to run a little better with it. also the exhaust smells more like old school diesel exhaust then other trucks without it.
    Did you do this before or after you located the downpipe
    The **** I have says it lubricates on the bottle, that's good enough for me.
    So you loose, I win!
  2. #62
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    Quote Originally Posted by Snatch Adams
  3. #63
    pwned?
  4. #64
    and why would you put ky in the diesel tank???
  5. #65
    May 2003
    Htown
    http://www.turbodieselregister.com/f...ht=dieselkleen
    dont know if yall can see that thread without an id, but there is someone using just about everything under the sun.
    edit: i just logged out and tried, and you cant see it.
  6. #66
    May 2003
    Htown
    Quote Originally Posted by DRAGOONRANCH
    ky is water based, that would be bad. God youre dumb
  7. #67
    um, thats why I was askin you tamoron.
  8. #68
    TAMOR Obsession Chadnutz's Avatar
    San Antonio
    Quote Originally Posted by fbronco86
    Yeah I am not into dudes with backnce.
    Go with chirst bra
    Phew, I'm not into fat ****ers Mr. Perfect.
  9. #69
    May 2003
    Htown
    umm you cant use a derogatory name against the person who coined said name within the first week of the word in question's conception. Its in the dickhead code of ethics.
  10. #70
    Well I am not a dickhead, so go get bent.
    ******* maybe, but not dickhead.
  11. #71
    Besides, I work for da debil, I have no ethics remember?
  12. #72
    Astroglide is petroleum based
  13. #73
    Oh Creighton, looky what I found. tee hee hee.
    Quote Originally Posted by EFI Support View Post
    LBZ DSP won't be released publicly until the end of this month. LMM will follow hopefully by the end of October.
    Cheers
    Cindy
    A little bit about the switch install: http://www.dieselplace.com/forum/sho...d.php?t=325872
  14. #74
    Dec 2005
    BFE, Tejas
    LB7 still mo betta!
  15. #75
    R2D2 rocks!
