Page 32 of 41 FirstFirst ... 22 28 29 30 31 32 33 34 35 36 ... LastLast
Results 466 to 480 of 607
Thread: The Barn Burner
  1. #466
    If you are going to have it apart, MRVB?
  2. #467
    ... TMatheaus's Avatar
    Nov 2005
    Bayou Vista
    Quote Originally Posted by tigweld View Post
    those small stacked plate coolers suck if thats thats what you are running. find a tube/fin type cooler they are much more efficient(but more expensive). when you are crawlin' you need to pull down into 1st and not use the automatic gear selection if you don't already.
    i think you are backwards, the fin type suck which is the style he has and the plate style are the better ones
    Tommy Matheaus '06
    210-323-2546
    2004 F-140 4x4 DD
    1990 F-150 4x4 in the works
  3. #468
    Quote Originally Posted by TMatheaus View Post
    This is what I have always been told
  4. #469
    I am talking radiator style with end tanks 2 pass maybe like this
    http://cgi.ebay.com/ebaymotors/Setra...Q5fCarQ5fParts
    I can tell you for a fact from personal experiance that the stacked plate do not work very well
  5. #470
    I misunderstood, I thought you were talking about something like this
    http://www.speedalliance.com/images/...ION_COOLER.jpg
  6. #471
    Aug 2005
    Houston or a drag strip
    It's back together and running once again. Mounted a badass trans cooler/e-fan setup in the bed, should have no problem keeping it cool under rompage. Need to make a mount for the trans temp gauge since there is no room on the dash.
    Built a winch mount yesterday using pieces from Coop's old one. Got it installed, just need to wire it up. Also welded on some d-ring mounts to the front for tow points.
    Started on a steering box brace using some scrap pieces of chromoly tubing. Not much left, just need to finish it up.
    I'll post pics later, headed back out to the shop.
    1974 CJ5-The BarnBurner
  7. #472
    Aug 2005
    Ready to rock n roll... Got it all finished up tonight, I forgot how much fun it is to mount the skidplate by yourself.
    Pics...
    For the winch mount brackets I welded two 3/8" grade 9 bolts from underneath for the studs. Also tapped single 7/16" grade 9 bolts on each side offset for additional strength against shearing.
    Steering box brace... Mounted the winch controller box flush underneath due to lack of mounting space on the actual winch. Might move it down the road...
    Trans cooler/fan
  8. #473
    Aug 2002
    that may be the worst placement for a winch controller box that I have ever seen
  9. #474
    Aug 2005
    Ya, with no mounting space on the bumper/winch and the short cable run to the terminals made my options slim. It's still easily accessible and protected by the bumper, steering box brace, etc.
    That being said I plan on mounting it inside the console I'm building for the c.b. and head unit later on.
  10. #475
    Jul 2006
    why not just put it on top of the winch motor with some very large hose clamps?
  11. #476
    DFW
    Quote Originally Posted by bcolman View Post
    x2?
    Or run it into your engine compartment and wire up some in cab controls from 12voltguy?
  12. #477
    Aug 2005
    Read above... No space to mount the box on the m8000 motor, I tried it as that's how our m12000 box is mounted. The 3 motor cables have to be lengthened to mount it any further than about 10"s from the winch terminals.
  13. #478
    Quote Originally Posted by FJAggie07 View Post
    x2?
    did you see the rest of the wiring on this vehicle? 12volt guy stuff wouldn't exactly match.
  14. #479
    Jul 2006
    i dont understand your logic, you could mount it under the winch, but you could not mount it to the motor where the wires would need to be ever shorter? maybe its just been a long week, but that doesnt make sense to me
  15. #480
    Whacha gonna do when the front end is burried into a dirt bank or something and you need a winch pull to get up it?
