Results 1 to 15 of 38
Thread: Finternational Brout
Hybrid View
    Registered Eckert's Avatar
    Nov 2006
    well, TTB brings the suck, to replace the passenger side shaft, you have to tear the entire front end apart. lame.
    I am guessing you broke the inner, inner shaft. You can replace the outer and middle shaft without removing the center section. But I am guessing you figured this out, If I were you, I would just do a straight axle swap, it is about the same amount of work...
    The splines on the slip part of the shaft are whats broke
