Almost flush to out a little.
So when i bought my truck there were some wires from the heater under the dash that you would just twist together to make it work. There is a hole cut in my heater box and two wires come out. I have tried every combination of power and ground to these wires but it still doesn't come on. What did the p.o do? How do i make it work?
it used to work, now it doesn't
define work, does the motor blow just not hot, does nothing happen, do you hear any noises electrical or not. we need more info
Did you check the fuses?
run a jumper wire to one from the hot side of the battery and ground the other. if that doesn't work do the opposite. if that still doesn't work then your motor is fried or maybe the resistor if you have one
So do you think the p.o just put new wires on the motor when the factory wiring stopped working? Whenever the motor was on it always blew hot.
sounds like its ben a victim of a a po's bad wiring. someone knowledgeable might have to take a loot at it
the red kind
On that note, **** Ford for using 4 different incompatible ATFs in the last decade.
