For you and your truck, keep it basic for now. I.e., no RMVB. If ford transmissions are like GMs, you can use the 2wd housing and internals, but you will need to swap out the tailshaft. This basically requires taking the whole ****ing transmission apart. Its not "hard" but can be intimidating since most people believe automatic transmissions work on voodoo and magic smoke. I have done this twice on GM TH400's and both worked, so take that for what its worth. The Hayne's transmission manual is suprisingly thorough, so that might be worth picking up. You can read through and look at the pictures before deciding if you are up to the challenge.
