Page 20 of 42 FirstFirst ... 10 16 17 18 19 20 21 22 23 24 30 ... LastLast
Results 286 to 300 of 620
Thread: '93 F-150 build
  1. #286
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    Quote Originally Posted by Hot Pocket View Post
    Will they fit on a 400? Lookin to sell?
    yes pm me
  2. #287
    Dec 2007
    i have a 33 gallon tank i dont need
  3. #288
    Jan 2010
    From a bronco?
  4. #289
    Dec 2007
    yes
  5. #290
    We have a few old exhaust systems with various size tube in the backyard that you can butcher for whatever.
  6. #291
    Jan 2010
    Good news, my fuel mileage has skyrocketed since putting in Clarkes transmission and a new torque converter. It used to take me 1 1/4 tanks to get home and today it took me 3/4 of a tank to get home. I also drove with the windows up which I never do but I don't think that really helped too much.
    I also took my truck in to get a recall taken care of. Apparently some part of the cruise control can make these trucks spontaneously catch on fire even when the key is off, so I figured it'd be good to get done. While there they were kind enough to do a "Multi Point Inspection" and I got a big packet about how every replacable part of my truck needs to be replaced and I need to spend more than I paid for the truck to do it. **** them.
  7. #292
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    ah, the exploder cruise control.
    thats why they're called stealerships.
  8. #293
    I wonder if they'll do one on my truck. That would be interesting ***
    F*ck off cj.
  9. #294
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    Hey sparling can you measure your front driveshaft for me? I would like you to measure from the center of the u-joint at the front axle where it meets the front driveshaft to the center of the front tcase flange or yoke whatever option your tcase has. Clear as mud? Thanks in advance.
  10. #295
    Jan 2010
    Here to here?
  11. #296
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    Yes sir thank you very much!! This helps out my homebrew doubler concept. I knew the e40d was a freakishly long trans.
  12. #297
    I dont think you should worry to much about front driveshaft length. My front driveshaft is super long with the front stretched and a doubler
  13. #298
    Jan 2010
    My truck isn't starting all the time, but after some persuasion with a hammer on the positive terminal it starts fine. The terminal is also corroding obscenely fast. Thoughts? There isn't any drain on the battery, and it'll start regardless of how long it sits as long as you play with the terminal a little.
  14. #299
    tighten it...............
    F*ck off cj.
  15. #300
    Once a battery starts corroding on the terminals, it will never stop. Parts stores carry aerosol battery terminal cleaner that is worth the money, but a terminal cleaning brush from harbor freight works well too. I would get both and just keep an eye on it.
