Results 1 to 13 of 13
Thread: Big Block Build
    Big Block Build
    This is in no way a complete total of the parts, but it should be a pretty good ballpark.
    Parts List: $4,433.20
    HEADS $2181.84
    Patriot Freedom Heads PAR-2211 x1 (set) $1,395.00
    Intake pushrods - CCA-7934-1 (Comp Cams) x8 $79.04
    Exhaust pushrods - CCA-7979-8 (Comp Cams) x1 $78.95
    ARP Head Bolt Kit ARP-135-3603 $92.95
    Comp Cams Roller Rockers CCA-1411-16 $145.95
    Comp Cams CB 260AH-12 249-K11-302-4 $389.95
    INTAKE $470.86
    Edelbrock Squarebore/Squareport Intake EDL-7522 x1 $384.88
    TBI Adapter Plate TRD-2210 x2 $85.98
    CLUTCH $312.85
    12" Centerforce 2 Disc CTF-384024 x1 $93.95
    12" Centerforce 2 Pressure Plate CTF-CFT361909 $183.95
    Throwout Bearing CTF-N1716 x1 $34.95
    COMPUTER and ACCESSORIES $370.07
    OBD1/USB Tuning Cable aldlobd1u x 1 $59.95
    TBI Computer #16197427 (v6 or v8 does not matter) x 2 (one for trail spare) $69.99 (on ebay)
    TBI V8 Computer Chip for #16197427 (must be v8) x 2 (one for trail spare) $29.99 (on ebay)
    16/18 gauge Delphi female terminal #12146448 x 70 $13.30
    20/22 gauge Delphi female terminal #12146447 x 70 $13.30
    32 cavity Delphi ECM connector #12110207 x 1 $1.99
    32 cavity Delphi Micro-pack 100 connector #12110113 x 1 $1.75
    2 cavity pigtail connector #12052641-ASM x 1 $8.99
    Delphi terminal removal tool #12031876 x 1 $17.99
    Delphi Micro-pack 100 TPA lock #12045889 x 4 $1.96
    G1 Memory adapter G1 x 1 $35.00
    Replacement memory chip 27SF512 x 2 $10.00
    FUEL DELIVERY $627.81
    16gal fuel cell w/ foam 2160D x1 $155.99
    #8AN Straight End SUM-220890B x4 $27.80
    #8AN 45deg End SUM-220886B x4 $55.80
    #8AN 90deg End SUM-220886B x3 $44.85
    #8AN Hose pre-cut 25' length SUM-230820 x1 $84.95
    #6AN Straight End SUM-220690B x1 $4.88
    #6AN 45deg End SUM-220686B x3 $41.85
    #6AN Hose pre-cut 10' length SUM-230610 x1 $39.95
    -6 AN to 14mm x 1.5 O-Ring RUS-648070 x2 $23.90
    -6 AN to 3/8 NPT SUM-220648B x2 $5.90
    BYPASS REGULATOR AEI-13301 $125.95
    BYPASS REGULATOR FITTING KIT 13301K1 $15.99 (Jegs)
    EXHAUST $315.95
    Headman Shorty Headers HED-68618 $315.95
    MISC. $153.82
    ENGINE BOLT KIT ARP-535-9701 $91.87
    ENGINE GASKET SET FEL-KS2618 $61.95
    Now just have to find the u-toob vids of the cam breakin.
    Chief
    Sep 2008
    cool stuff ed
    Aug 2002
    there's a part or two missing off that list but I can't quite place it...oh wait I got it! the big block!
    600 bones for a running 454, not smoking deal, but worked out so far.
    Aug 2002
    stock bottom end on that mota?
    yes, for now
    Man I love storing information like this! Luckily I looked up the fuel pressure regulator that I had to make sure it was able to handle the 45psi the new fool injection requires and saw it needed the heavier spring installed for that. Might just have saved my weekend!
    More details please!!
    Picked up a Holley Terminator EFI kit. Its a newish version of TBI best I can 'splain it. Lots of wires I wasn't expecting, but should work well once the fuel pump is in. The one I have now is maxing out at 30.
    Trail Pimp Busa's Avatar
    Sep 2003
    Anderson, Texas
    I may have some of those flitting on you list I need sale. If you haven't bought any let let me know. Send me a text 972-281-7106. All of my fittings are Fragola.
    Ryan Busa
    CP# 972-281-7106
    rbusatoy@hotmail.com
    I already have the parts, thanks though.
