if i'm already dropping the coin for a 1 ton swap.........might as well go big
Dude, this is way bigger than one ton. The axles are more, you'll have to get some wheels re-centered, new tires most likely, are you going to stay with leafs in the rear?, you'll need lots of lift to fit them under, if you're going with 2 steer axles you'll need to do hydro on the rear if not both, and I'm sure lots of other things I'm not thinking of.
4 links f&r some way to steer the rear axles..........and some shredders haha
y rockwells? are you wanting to turn the bronco into a mud truck? To me, and the only reason i got a set was that my plans are to start from scratch with my ranger. With your bronco you would have to lift it atleast 10" in order to clear the dif and have and uptravel, thus making it usless for any kind of wheeling this club does or what you want to do in CO.
Dont get me wrong, rockwells are AWESOME, but not for your needs. Get the bronco running right and work on your 1 ton swap first
http://www.pirate4x4.com/forum/showt...=rockwell+irok
http://www.youtube.com/watch?v=iPxavVv6Mp4
now get to work with your stick welder
and $100k
Jesus Tommy you're getting in WAY over your head. You need to take it one step at a time and get some seat time before going balls deep on a build. Otherwise you will get 1/2-3/4 finished and give up, selling everything at a retardedly huge loss. Rockwells might be a small jump price-wise compared to one tons but they are a flying ****ing leap work-wise. As Clarke said you would have to jack it way up and do buku fab work that you arent capable of yet. You can also assume that any rockwell you buy for a reasonable price will be in $hit condition and need to be rebuilt. This all isnt even begining to delve into the idea of rear steer.
Slow down.
Going to rocks is a lifestyle choice for sure. Everyone has given you plenty of reasons not to do this. To keep from getting a rash of ****, you are going to have to come up w/ something better than TTC.
I still hold that my tons are as strong as a stock set of rocks. I get ease of installation, cheaper rebuilds (bearings, gears and such), no need to run extreme sized tires and weight reduction (less stress on suspension parts), versus strength of actual axle, raised driveline, option for stronger shafts and ability to run the biggest meats.
There may be other things I am not thinking of, but that should be about the jist of it.
brakes would be there biggest draw back to me. to get wheel brakes on them you need access to a machine shop or big time $$$$ to get it done
The LT1 is an elusive creature that has "reverse cooling". For those that do not know, this means the water goes from the radiator, to the heads, to the block, and then back to the radiator. There is a water pump in there. As a result you have to have the radiator full all the time or the engine will not get cooling water (kind of a big deal with aluminum heads).
My question is this, how do you set this up on a swap, say a 1965 chevelle. Do you just make sure you have a good reservoir and keep it full.
Thoughts? I googled on the internet and found some article that I think is blowing smoke up my anus saying the LT1's have special radiators and all kinds of crap. Comments?
