Is the green 60 complete/ for sale?
It is torn down somewhat right now and will have dually hubs w/ it right now as I swapped the single wheel hubs onto the beast. It also has a bunch of bracketry welded on it for a fourlink and dual single ended cylinders for steering.
I am sure I want way too much for it right now, and I would want to sell the 14b along w/ it, and it is missing the carrier and ring gear (I think I still have the ring gear somewhere, just not sure).
As far as I know yes, they are the common 4 prong stock nuts. I remember reading on pirate awhile back about some fancy aftermarket nuts that are somehow garaunteed not to come loose but a quick google search didnt turn anything up. I half-assed want to replace my front nuts with 6 prong units to match the 14 bolts' so I'll only need one socket, but havent ever actually put any effort towards that endeavour. A complete kit is available here http://completeoffroad.com/i-123167-...60-6prong.html
Oh, I see. When you handed me the 6 prong when we were putting the hubs back on, I just assumed that was what you had on yours.
In my never-ending quest to make my High Angle Driveline t-case e-brake work, I think I have finally settled on this lever
Found herehttp://store.colemans.com/cart/emerg...dle-p-721.html
Its prety simple, rugged and cheap, so I believe it will get the job done nicely. Yes, I have seen the Lokar lever and I like this one better. Its uglier, more durable looking, and cheaper. Win. The only thing that sucks is that website has a $15 minimum order, so I might buy one of their overpriced ammo cans to bump my total up unless someone else wants something from there.
The next item of concern is the jacketed cable needed to connect the lever to the arm on the brake caliper. I cant be sure exactly how everything will fit into place without having the parts in hand, but if it works out the way I am envisioning it in my head, the cable will need to be ~18-24" long. The cable needs to have a 2-3" stroke and I have no idea what the tensile stress on the cable will be, but 100 pounds seems like a good start. Finding a cable this short seems to be an issue. McMaster Carr p/n 3125K89 is the shortest I've been able to locate at 3 feet long and I can probably make it work. Each end is 9 1/2" long which leaves ~17" of flexi-ness in the middle.
You don't need a few extra 10-bolts to hold your back yard down?
http://store.colemans.com/cart/front...-gi-p-849.html
thats actually a good deal for someone just keeping a stock blazer on the road. shipping kill it?
Sharpe, are you guys 100% sure that my e-brake and CV flange for the atlas never showed up from high-angle? I was checking yesterday to make sure it had been paid for so that I could call Jess and find out where it's at. Either way, order me one of the levers too if that will get you over the minimum order.
Yah, there's deff no **** from HAD here for you. My stuff is easily identifiable because it has ~6 years worth of storage rust and dust on it.
Yeah, we had discussed this before, but I wanted to double check before I throw this back at him.![]()
I'll take one Sharp.
I'm not sure if these are over priced, but if not, I'll take one of these also: http://store.colemans.com/cart/ammo-...-mm-p-225.html
Maybe shipping them is $$?
Only the .30 and .50 cal cans are about twice the going rate. The larger ones are prety well priced but shipping on them is killer. I usually get the bigger ones at gun shows.
