Very well thought out and methodical testing of winches. Also very interesting final result numbers.
http://www.moabjeeper.com/articles/g...?articleID=353
[IMG]http://i54.photobucket.com/albums/g94/hardlinecustom/Silly****/HNLWHEELIN003.jpg[/IMG]
Tires like to fall off wide wheels at low pressures. Most use a wheel about 2" narrower than the tire. I really think a wheel about 4" narrower than the tire is the way to go for offroad+highway. Tire stays on better, sidewall is better protected, and still wears right. Go skinnier on the wheel and the tire will wear in the center too much.
pretty sure the yoke i have is 1350 and 30 spline. from what i read it can be a 14B yoke or np205? how do i tell? u bolt style
the only number stamped on it is '19'
if it is a d60 1350 i have on in my truck right now you could compare it to, give me a call after tomorow
I have a 27 spline np 203 input if that helps.
So I have an '86 Ford 460 with the good ole Duraspark Version 2 on it. The other day it would not start, so I check fuel, spark and no spark. So, go through wires, cap, distributor and I find the "magic box" is bad. I get one from O'reilly's for $26, replace it and everything is good. My question is this, what makes these boxes go out? I ask because when I found where the magic box was, there were 2 of them. Apparently the original went out and rather than remove it, they just bolted the new one next to it, that went out on me. Seems like a repeat problem for this vehicle. Ideas?
Was there a puddle of melted wax down the fenderwell below it? Usually heat kills them when it melts that wax-like stuff and exposes the electronics to moisture.
