My wife's friend asked for help on this. Anything I should know? It's a tilt column.
its the same one that your blazer had. didn't you replace that with a light switch?
If its the same as a Chevy, you have to drop the column and its mounted on top. Prety easy to replace. and only like $20 or so.
yep like they said it's the same as chevy, here is an awesome write up on everything cj column related. it should tell you everything you need to know. . . http://www.epiccomputer.com/dale/jee...tilt/tilt.html
