i prefer to cut down full sized axles and then bolt them into cj's without outbording. ive done it several times for different people and am about to do it to a 60.... to each his own
I've been thinking about how im going to fit my exhaust under the rig and because of how tight everything is (and lack of money) I plan on doing it myself. So my question is, what is the general consensus on useing the flexible exhaust pipe?
http://shop.advanceautoparts.com/web...ci_sku=5600031
Will it hold up? Is it complete crap? Will it work for a relatively tight bend?
Edit* just to clarify, I want to use the flex pipe at the down pipe where the exhaust bends and heads to the rear of the jeep.
the only thing i would "exhaust" with that is my dryer
you could get it done right by someone else for around $100 so just work a couple hours overtime and dont be gay
i dont have any experience with the flexible exhaust pipe but i do know that big rigs use it so there must be some out there that is worth a dam
There is almost no room for my exhaust, I imagine it would cost alot more than $100 for someone to do it, if I could find someone willing to do it at all.... Im no exhaust expert but im pretty sure the skid will have to be removed and reinstalled multiple times to make all the bends necessary for it to all fit.
Sooo.. back to my question. Is the flex pipe worth a damn? If it is, it will make the hardest part of the whole thing be pretty easy.
it might work but seems ghetto to me... and that is coming from a guy that re-used old frame
Don't use it unless you plan to keep it for a short time. It is ok in a street application, but on a rig that will see a good bit of flex it will wear out pretty quick. Especially if you are using it coming right off the engine where it will see the most movement. I am sure that Rusty can get your hard bends put in for the C-note and you could finish out the rest. Building it all yourself wouldn't be a bad 'learning experience though. May have to do that on mine once it's all said and done to really tuck it up like it needs to be.
There is a guy in Bryan off south college close to the bend, that did an awesome job on my bronco tucking it up tight. I supplied the muffler and I think it was around $250 and worth every penny. I think some people will disagree with me, but from the two times I tried to use him he sucked. Rusty can go blow his trombone that guy is a douche.
I think the key to having Rusty doing a good job is to not get it done on Saturday right before he is closing (and right before you need to be taking off on a ~4000 mile round trip )
My rusty experience has also been so-so. He does do decent work, just not high on my cestomer service scale.
Thanks Ed that is exactly what I wanted to know. I guess that means i'll be spending some time doing exhaust work. I will not take my stuff to Rusty's even if he can do a good job. That guy is an a$$. Besides judging by my last experience with him, he wont do my exhaust without putting a $200 catalytic converter on it....
i have used mcalister and sons on texas, they do good work, they did give me some grief about not putting on a cat so they just ran the pipe to that point and then i put my muffler on it
