When idling in any gear, if I punch the gas, the RPMs drop quickly, and then it will either rev back up , or die completly.
I had a new spare IAC that I put on and I also relaced the TPS. No change. pulled the O2 and hit it with some electric parts cleaner. Also checked for vaccuum leaks. Fuel pressure is 34ish, and will jump to 42ish when the I take the vaccuum away from the regulator, which is what the Haynes says it is suppose to do. I pulled a few plugs and they all looked great. At a loss. Any more ideas? Flem?
