Page 30 of 42 FirstFirst ... 20 26 27 28 29 30 31 32 33 34 40 ... LastLast
Results 436 to 450 of 628
Thread: Who had March 14th?
  1. #436
    you can have my mech fuel pump if you buy me a block off plate ($6 on summit). I bought it last dec. I have an electric one now for fool injection.
    Your pump is located on the drivers side of the block. Just follow the metal fuel line down to the side of the block.
    Oh, and mine had 2 fuel filters, one was inside the frame rail right under the door. Check that one. On the way back from k2 last year my truck kept shutting off and we couldn't figure out why. We took off the filter, which was pretty new I might add and it was clogged. We waited till we bought a new coil to figure that out though.......
  2. #437
    Chief
    Sep 2008
    It's the thing right next to the oil filter correct??
  3. #438
    Quote Originally Posted by Hot Pocket View Post
    yeah
  4. #439
    Chief
    Sep 2008
    Replaced the fuel pump today. Carb is still not supplying fuel. I replaced the fuel filter as well. Found out that the P.O. decided to eliminate the fuel filter located under the driver side door, so the truck only has the filter right before the carb.
    Either way, truck won't start. Looking at carburetor issues now, Can anyone tell me where to go from here?
  5. #440
    tbi
    ready, go!
  6. #441
    tbi
    ready, go!
    Because that was so easy for you to do?
  7. #442
    Not easy but really worth it
  8. #443
    Jul 2006
    i know little to nothing about carbs, but your float could be stuck and thus not supplying fuel to the engine
  9. #444
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    And it doesn't matter if your filter is new. Bad fuel can clog a filter pretty fast especially if all you have is the one.
  10. #445
    Do you have starter fluid? If you spray some down the intake and try to crank, does it begin to start or nothing? If it does not try to start you have a spark issue.
  11. #446
    Chief
    Sep 2008
    The fuel is maybe a couple months old. I don't think it's bad at all.
    I don't, but I know that I do have spark. When I work the throttle lever, the carb does not supply any fuel. This is a fuel/ carb issue.
  12. #447
    Un-do the fuel line at the carb, crank the engine and see if you get fuel out. You might have vapor locked it somehow.
  13. #448
    How much fuel is in the tank right now? Put the main filter back in if at all possible. There was probably a reason the PO took it off, and that reason was more than likely NOT a good one.
  14. #449
    Chief
    Sep 2008
    It's got about 6 gallons in the tank. I'll go get another fuel filter for it tomorrow after I get everything with school and moving done today.
    I undid the fuel line at the carb and cranked it, and nothing came out.
    Is it possible I installed the fuel pump incorrectly?
  15. #450
    see if the pump is creating vacuum on the gas tank side of it. unhook it and put your hand over it or something while starting the engine.
