Page 41 of 56 FirstFirst ... 31 37 38 39 40 41 42 43 44 45 51 ... LastLast
Results 601 to 615 of 839
Thread: Roxanne: 1985 Cj-7
  1. #601
    I was gonna hold out as long as I could but I'm a giddy school girl.
    I've been busy finding deals over the past 8 months, my wallet feels lighter but I saved a ton of money by getting good opportunities.
    The upgrade list includes (everything is new and in box):
    A set of Yukon 297x Superjoints
    http://eastcoastgearsupply.com/i-135...er-joints.html
    $250 shipped
    A pair of Superior EVO 4340 d-44 stub shafts
    http://www.superioraxlegear.com/stub...t-p-14500.html
    $200 shipped
    M.O.R.E. steering box relocation bracket
    http://www.mountainoffroad.com/_e/St..._CJ_7_CJ_8.htm
    $80 shipped
    Great Lakes off-road Ford 9" Pinion guard
    http://www.greatlakeoffroad.com/GLO-...oke-Guard.html
    $60 shipped
    Superwinch LP8500 with mounting plate, roller fairlead, steel hawse fairlead, snatch block and two d-rings
    http://www.superwinch.com/products/p...0.0.0.0?pp=25&
    $400 pickup
    Two H3r 2.5lb dry chemical fire extinguishers
    http://www.4wheelparts.com/Tools/2-5...t_pn=H3RMX250B
    $109 shipped
    Tuffy Deluxe 6.5" wide stereo console
    http://www.tuffyproducts.com/p-95-02...6-12-wide.aspx
    $100 shipped
    Rockstomper behind axle dana 44 highsteer arms with 1" spacers and 4" studs
    http://www.rockstomper.com/catalog/s.../highsteer.htm
    $175 shipped
    And the big stuff:
    JB conversion:
    4:1 gear set
    http://www.jbconversions.com/products/dana300/
    32 spline rear output with 1310 cv yoke
    http://www.jbconversions.com/product...0/rear_out.php
    32 spline front output with 1310 standard yoke
    http://www.jbconversions.com/product.../front_out.php
    Clocking kit with 23 spline input
    http://www.jbconversions.com/products/dana300/plate.php
    Full rebuild kit
    http://www.jbconversions.com/product...00/rebuild.php
    Novak Twin stick kit with boot
    http://www.novak-adapt.com/catalog/d...twin_stick.htm
    High-angle Driveline, 2 1350 u-joint 32 spline output flanges
    http://www.highangledriveline.com/new_products.html
    ALL OF IT FOR $1100 shipped!
    So ya, I spent some money. But I saved more then I spent in total. Plus when I finally get back to work on this thing I will have even more parts to sell that are coming off. So I can recoup some loss there as well.
    Excited! This thing is going to be a beast with 130:1 gearing and 100" wheelbase!
    i dont speak australian.
    seacrest, you are my hero!
  2. #602
    why don't you just get a used atlas and have a better t-case then a polished turd that will crack the case
  3. #603
    LowMax gears are bigger and better than Atlas gears. I have been researching the stock case as the weak link issue and it is not that big of a deal. I do plan on making a case girdle connecting from the rear output to the inspection cover to strengthen it. People have good success with this. There is also a replace-a-case option if something does happen.
    Coop is running his d-300 and has had no problems.
    With that said, I will make you a deal, if you can find an atlas or stak of equal gearing/outputs/ex. for $800 then I will buy it and you can keep it!
    BTW: the d-300 is in no way a turd
  4. #604
    Hazaa Fredo's Avatar
    $100 shipped
    OH **** YEAH! Better make sure your balls are screwed on tight!
  5. #605
    You know it!
    I'm just excited that I'll finally be able to play some tunes.
  6. #606
    Nov 2002
    Tx
    $250 shipped
    $200 shipped
    $80 shipped
    $60 shipped
    $400 pickup
    $109 shipped
    $100 shipped
    $175 shipped
    JB conversion:
    4:1 gear set
    Full rebuild kit
    Learning to drive stick - priceless...
  7. #607
    Quote Originally Posted by mudtoy67 View Post
    I found out to combat case flex with the d-300 that people are using the inspection cover from a d-20 which is thicker and hold greater capacity.
    I'm thinking of going this route as well as making a 1/4" flange that extends out to to the rear output.
    http://www.4wheelers.com/jeep-dana-2...43-p-2610.html
    However, I found these and could also go this route. Just think mine would be stronger and cheaper.
    http://www.wildhorses4x4.com/product..._Transfer_Case
    http://www.bjsoffroad.com/CartGenie/prod-1048.htm
    This is a d-20 but the same thing could easily be built for the d-300.
  8. #608
    thats a dana 18
    on a 20/300 the plate where the 18 rear yoke is used for bearing preload.
  9. #609
    thats a dana 18
    Your right, I typed it wrong. Taken from this build:http://www.jeepsunlimited.com/mambo2...d=43&Itemid=30
  10. #610
    I was supposed to be doing thesis work but I got bored and started playing with microsoft-paint. Future paint and tube work.Attachment 18584Name:  Picture1.jpg
  11. #611
    So we're talking axle width.
    Width of front 63.5" WMS
    Width of rear 60" WMS
    Difference of 1.75" per side
    I have some 1" spacers and was thinking that the slightly wider rear would add to stability. So what set-up would you rather run? The above or below.
    Width of rear 62" WMS
    Difference of 0.75" per side
    Thanks for the opinions.
  12. #612
    sam_hodnett's Avatar
    Feb 2010
    ETMF Land
    bottom one
  13. #613
    Boost Junkie breckboarder55's Avatar
    Sep 2008
    CS
    How often is the Jeep being started/driven?
    SHUT UP AND WHEEL
  14. #614
    Quote Originally Posted by breckboarder55 View Post
    You mean over the past year? or when I get back?
    The jeep hasn't moved/started since June 2010.
    When I get back it will prob be driven around about once a week, maybe more depending on where I get settled in.
  15. #615
    The top set of numbers will be better for making turns I believe.
