copious amounts of black smoke fixes all my HID issues. Its not the ones coming towards me i have a problem with, its the ones from behind
My daily driver is green, 14' long and powered by suzuki.
I would have to be a fool to have something like this as a real wheeling rig. It weighs 7800 lbs. Have you seen my jeep? This is just a light duty wheeler, should hold up pretty well once I put a traction bar on the back, has inferior springs. It will also be my daily driver (if I drove daily) for the next year or so. After that it will get real tires and a winch.
I've been working on fixing all the little things that have come up and been ignored over the past 250K miles. Has working air conditioning, door locks, and stereo now. Also installed a new dash and glued/screwed other interior trim back on. I put new shocks on the back, front will be done soon. My OBA parts just came in, so that's next on the list, just a york with a tank under the bed. If you ever need anything from Kilby, allow a month to order and get it, took me about a week just to order.
I finally got the headlights shining good, polished the lenses. That really makes a big difference, at least 4x brighter. Something still isn't right, might be out of adjustment.
Installed the OBA. Tested it against my dads 10 cfm gas powered compressor, they're about the same. Think mines a bit faster. Set the pressure to 150 so my cheap air tools work better.
Upgrade the stock wiring harness so that the power is coming from a relay from the battery and not thru the hl switch. does wonders. that stock wiring sucks. and if your really feeling frisky you can upgrade to sport headlights and have two extra bulbs. thats what i did and it is an amazing difference...
I've been meaning to do the relay thing for a few years. Think Scott did it on his old dodge too.
This thing is a bad dood, ripped the trailer apart.
that would be funnier if i wasn't aware of that trailers design...
