Page 46 of 132 FirstFirst ... 36 42 43 44 45 46 47 48 49 50 56 96 ... LastLast
Results 676 to 690 of 1980
Thread: Sloth
  1. #676
    The XXX kit is a parallel 4 link with a panhard. Good for mostly street driving, not so much for crawling. Regardless, any kind of link suspension is beyond Tummy's budget and fabrication skills so my vote goes to leaf springs. Do NOT tear the axle down. No good can come of it.
    Just curious but why do you say this?
  2. #677
    Tommy- new plan, 4 easy steps to lift your truck
    1) BFH to correct the radius arms for your narrower frame
    2) weld these to your frame:
    3) use Evans coil buckets and bolt up the coils, shocks, drag link
    4) Sit in the driver's seat and make engine noises because your **** is still ****ed
  3. #678
    Fabtech arms look like ****. There's not enough room to move the radius arm in, so ill have to bent it in or outward the top mounts
  4. #679
    Parrallel 4 link or radius arms for more flex?
  5. #680
    Jan 2010
    4 link is going to cost a lot more and it still depends on how you set it up. I think a well set up radius arm suspension will be cheaper, easier and work just as well. Count up how much 10 of whatever rod ends you'd use and 10 tube adapters for them plus a few hundred dollars in DOM
  6. #681
    Nov 2002
    Tx
    I don't see 4 link being that much more expensive.
    He's got to build a track bar for either suspension.
    He's already got two rod ends on the radius arms
    The axle end has bushings no rod ends there.
    So at most he has to buy 2 additional rod ends and tube adapters.
  7. #682
    I'm with BDR
    Will 2x.250 DOM hold up for lower links?
  8. #683
    and don't cut anything off of the axle so when you scrap the bronco I can buy it and use it for my Dirtymax SAS
  9. #684
    What kind of ***** ass 3/4 ton truck doesn't have a solid front axle? I will melt it down just to spite you.
  10. #685
    One that can outrun a Ford
  11. #686
    Still has ifs gheyness
  12. #687
    DFW
    Who needs a solid axle to pull a trailer? Why would someone sacrifice drivability and ride comfort in a 3/4 ton truck just to say they have a solid axle?
  13. #688
    Alot of 3/4ton and 1 ton trucks do not have the plush life of back and forth to work on the highway and pulling a trailer 5 times a year like yours does. Alot of them are used in more adverse everday working type conditions and in this aspect, one could argue that a solid front axle is more 'heavy 'duty, than an IFS setup.
  14. #689
    http://books.sae.org/book-r-114
    I think this would be the first textbook I would actually read.
  15. #690
    Rawr TexTJ209's Avatar
    Waco, Tx
    Quote Originally Posted by JB View Post
    But on that note, I think the GM trucks have more than proven their IFS is durable over the years.
    '81 CJ7 Laredo, 258/T176/D300
